はじめに
There are a few important things to recognize when replacing the charge port. The connection between ribbon cable and motherboard is initially tricky, but when you've loosened the connection, the ribbon cable will slide right out. There is some adhesive between the ribbon cable and the device near the charge port. It's okay to pull this loose because your new charge port will have more adhesive.
パーツ
パーツは指定されていません。
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
6 の人々がこのガイドを完成させました。
