メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
With the emergence of more and more curved-screen mobile phones on the market, curved-screen technology becomes more and more complicated, adding the difficulty of curved-screen refurbishing. The release of Samsung S9 series also brings a new challenge since traditional curved-screen refurbishing solutions with freeze assistance cannot meet its need. That's why we bring you this latest curved-screen refurbishing solution with heat assistance, which can meet the refurbishing needs of most curved-screen and flexible-screen mobile phones.
ビデオの概要
  1. Get the S9 OLED screen assembly connected. Press the power button to turn on the phone.
    • Get the S9 OLED screen assembly connected. Press the power button to turn on the phone.
    • Enter *#0*# using the dial pad. The phone will immediately go into its secret diagnostic mode.
    • All going well.
  2. Let’s start with glass lens cutting. We need to cut through the glass lens area between the earpiece speaker and OLED.
    • Let’s start with glass lens cutting. We need to cut through the glass lens area between the earpiece speaker and OLED.
    • Place the OLED screen assembly onto the operating panel of the cutting machine. Adjust the cutting blade. Slide back and forth to cut the glass lens.
  3. Fix the OLED screen assembly onto the operating panel of the separating machine. Pry off the top glass lens with the blade first. Then break the upper left and upper right corner of the glass lens with a breaker.
    • Fix the OLED screen assembly onto the operating panel of the separating machine.
    • Pry off the top glass lens with the blade first. Then break the upper left and upper right corner of the glass lens with a breaker.
    • Once done, a part of the OLED is exposed so that the LCD Cutting Wire can make its way through the gap against the glass lens.
    • Pull the cutting wire to separate the glass lens from OLED.
  4. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  5. Now we need to remove residual glue on the OLED with the Electric Glue Removing Device.
    • Now we need to remove residual glue on the OLED with the Electric Glue Removing Device.
    • Once done, clean thoroughly with glue remover soaked nanosponge.
  6. Since the OLED is glued to the Mid-frame by Mid-frame adhesive strip, we need to insert metal pry piece to separate the adhesive strip from the Mid-frame. Then insert metal pry piece to separate the adhesive strip from OLED.
    • Since the OLED is glued to the Mid-frame by Mid-frame adhesive strip, we need to insert metal pry piece to separate the adhesive strip from the Mid-frame.
    • Then insert metal pry piece to separate the adhesive strip from OLED.
    • Pull the adhesive strip out slowly and completely.
    • Continue to slice through adhesive underneath the four corners and the backside of OLED.
    • Now the OLED has been separated completely from the Mid-frame. Test again.
  7. Embed the OCA rubber block aligning mold into the base. Place OCA into the corresponding position of the OCA aligning mold. Then embed the OCA aligning mold into the base.
    • Embed the OCA rubber block aligning mold into the base. Place OCA into the corresponding position of the OCA aligning mold. Then embed the OCA aligning mold into the base.
    • Place the new glass lens into the glass lens mold. Embed the glass lens mold into the base. Place the whole mold into the laminating machine.
    • Then solidify the OCA laminated glass lens in the High Power UV Lamp for 5s. The glass lens and the OCA have been laminated successfully.
  8. Place the OCA laminated glass lens into the glass lens mold. Embed the OLED rubber block aligning mold into the base.
    • Place the OCA laminated glass lens into the glass lens mold. Embed the OLED rubber block aligning mold into the base.
    • Place the OLED screen into the OLED aligning mold. Then embed the OLED aligning mold into the base.
    • Once done, remove the OLED aligning mold. Clean the OLED screen thoroughly with N-hexane.
    • Tear off the OCA protective film. Then embed the glass lens mold into the base.
    • Continue to place the whole mold into the laminating machine. Once finished, solidify the OLED screen assembly in the High Power UV Lamp for 3 minutes.
  9. Put the OLED screen assembly into the Bubble Removing Machine for 10 minutes. Once finished, take out the OLED screen assembly.
    • Put the OLED screen assembly into the Bubble Removing Machine for 10 minutes. Once finished, take out the OLED screen assembly.
  10. Again, let's test the refurbished screen. All going well.
    • Again, let's test the refurbished screen. All going well.
Phryne
メンバー登録日: 2019年11月17日
10,181 ポイント
80のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 10
過去 7 日: 86
過去 30 日: 504
今までの合計 1,172
