メインコンテンツにスキップ
Samsung Galaxy S8 Plus Motherboard Replacement
必要な工具と部品
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alex Sander
メンバー登録日: 02/28/17
38,195 ポイント
202のガイドは作成済み
3 件のコメント
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - 返信
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - 返信
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 50
今までの合計 10,881
