メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to replace the NFC antenna and charging coil in your Samsung Galaxy S8.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
  5. In the following steps you will be cutting through the adhesive around the edge of the rear glass panel. The adhesive on the rear case is laid out as seen in the first image.
    • In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
    • The adhesive on the rear case is laid out as seen in the first image.
    • The prying pattern as seen from the outside of the phone is as follows:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying here, to protect the fingerprint sensor.
  6. 全てのタブを開く
    Mac用RAMアップグレードキット
    キット商品を見る
    どれだけタブを開いても
    十分に足りるRAM容量
    キット商品を見る
  7. Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge. The suction cup will not make a good seal on the curved portion of the glass.
    • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup, and insert a halberd spudger, or opening pick, under the rear glass.
    • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
  8. Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
    • Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  9. Slide an opening pick or the blade of a Halberd spudger down the side of the phone, separating the adhesive. Go slowly so that the tool doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
    • Slide an opening pick or the blade of a Halberd spudger down the side of the phone, separating the adhesive.
    • Go slowly so that the tool doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
  10. Repeat the previous heating and cutting procedure for the remaining three sides of the phone. Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing. Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
  11. The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed. As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
    • The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed.
    • As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
    • Use the opening picks to slice through any remaining adhesive and open the phone slightly.
    • If the fingerprint sensor cable seems snagged or stays taut do not open the phone any further. Disconnect the connector with the point of a spudger before proceeding.
    • During reassembly, in order to reconnect the fingerprint sensor cable, first angle the back cover into position until the cable connector lines up perfectly over its socket. Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
    • Remove the glass from the phone.
  12. To install a new back cover:
    • To install a new back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • Follow this guide to reinstall the old back cover, or to install a back cover without pre-installed adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
    • You may also need to transfer the camera bezel to your new part. If that's the case, follow our camera bezel replacement guide.
  13. Remove eleven 3.7 mm screws.
    • Remove eleven 3.7 mm screws.
  14. Remove the NFC antenna and charging coil assembly. Remove the NFC antenna and charging coil assembly.
    • Remove the NFC antenna and charging coil assembly.
終わりに
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
6 の人々がこのガイドを完成させました。
Adam O'Camb
メンバー登録日: 2015年04月11日
100,610 ポイント
293のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
129 メンバー
12,526のガイドは作成済み
5 件のコメント
Can I leave off the charging coil? I don't use the wireless charging..
Stacy Rowe Ruggles - 返信
Hi Stacy, the assembly that includes the wireless charging coil also houses antennas related to NFC and other phone functions. Most things might still work if you left the coil out, but I definitely wouldn’t recommend removing it.
Adam O'Camb -
Hi adam thanks for the guide. It helped a lot. I have a question could you please guide me how to hotwire the charging coil pins. Because as i connect the coil it will cause the black lines in the screen and as i remove it the black lines are gone but the phone wont charge showing the low temperature. As removing the coil somehow disconnects the charging mechanism. Thanks in advance.
Rohan Raj Shrestha - 返信
Hi , my phone battery was going bad and it was overheating and sometimes would turn off when i was using it. know it is saying that the temperature is too low and this is after i changed the battery would removing the NFC antenna and charging coil stop this from happening
Catalina Funes - 返信
where i get repair my Samsung s8 mobile , it showing temperature low , pls send me address
translink01 - 返信
コメントを追加
統計データを表示:
過去 24時間: 10
過去 7 日: 93
過去 30 日: 302
今までの合計 14,657
