メインコンテンツにスキップ
Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement
必要な工具と部品
  1. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement, SIM Tray/Card: 手順 1、 2の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement, SIM Tray/Card: 手順 1、 2の画像 2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement, NFC Antenna and Charging Coil Assembly: 手順 2、 3の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement, NFC Antenna and Charging Coil Assembly: 手順 2、 3の画像 2 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement, NFC Antenna and Charging Coil Assembly: 手順 2、 3の画像 3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
  3. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 3、 1の画像 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 4、 3の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 4、 3の画像 2 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 4、 3の画像 3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 5、 1の画像 1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 6、 2の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 6、 2の画像 2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 7、 3の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 7、 3の画像 2 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 7、 3の画像 3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
  8. Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 8、 2の画像 1 Samsung Galaxy S8 Active NFC Antenna and Charging Coil Assembly Replacement: 手順 8、 2の画像 2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ariel Sampson
メンバー登録日: 01/24/19
709 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S2-G1, White Winter 2019 Cal Poly, Team S2-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S2G1
3 メンバー
11のガイドは作成済み
コメント 1 件
I cannot find a place to purchases a replacement of this for this particular phone, is there a difference between the NFC antenna/charging coil of the S8 active and the S8?
David Clair II - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 2,502
