メインコンテンツにスキップ
Samsung Galaxy S8 Active Camera Glass Replacement
必要な工具と部品
  1. Samsung Galaxy S8 Active Camera Glass Replacement, Camera Glass: 手順 1、 1の画像 1
    • Lay phone face down and remove any coverings to the camera area. This way there are no obstructions to the repair area.
  2. Samsung Galaxy S8 Active Camera Glass Replacement: 手順 2、 1の画像 1
    • Turn on the heat gun and hold it 3-4 inches from the glass for 5 seconds, waving it gently over the area to evenly distribute heat.
    • It may be helpful to keep the case on during this step, to avoid excessively heating the adhesive of the back panel.
  3. Samsung Galaxy S8 Active Camera Glass Replacement: 手順 3、 2の画像 1 Samsung Galaxy S8 Active Camera Glass Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently remove the glass with tweezers.
    • If the adhesive is still strong, utilize the heat gun for another 3-5 seconds, waving it over the area.
  4. Samsung Galaxy S8 Active Camera Glass Replacement: 手順 4、 1の画像 1
    • Check the surface for any residue or broken glass from previous cover.
  5. Samsung Galaxy S8 Active Camera Glass Replacement: 手順 5、 1の画像 1
    • Center the new glass over the camera lens and lower it to the phone, careful to not scratch the exposed camera lens.
  6. Samsung Galaxy S8 Active Camera Glass Replacement: 手順 6、 1の画像 1
    • Press gently on the perimeter of the glass to ensure a strong bond between the glass and the phone, but not pressing hard enough to break the glass.
終わりに
The device should be in working condition after the last step. Be sure to turn on the phone and verify to see if there are any obstructions to the camera view caused by the new glass covering.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Anirudh Iyengar
メンバー登録日: 02/01/20
142 ポイント
1ガイドが承認済み
コメント 1 件
Did you use the rear camera glass from Amazon that you've put a link to under parts? The Amazon seller has stated that it doesn't fit the Samsung S8 Active so unsure whether to purchase. Thanks
Natasha Wightman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 855
