メインコンテンツにスキップ
Samsung Galaxy S7 Home Button Replacement
必要な工具と部品
ビデオインストラクション
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
MovilOne
メンバー登録日: 06/17/14
2,480 ポイント
14のガイドは作成済み
5 件のコメント
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - 返信
Thanks for you info.
www.movilone.es
MovilOne - 返信
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - 返信
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 17,832
