必要な工具と部品
ビデオの概要
Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers.
At last, push the camera lens glass by your finger or with a spudger and remove it finally.
54 の人々がこのガイドを完成させました。
27 件のコメント
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Yes, that is possible!
Robin -
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
