はじめに
Use this guide to uninstall and replace the motherboard from your phone. After uninstalling the motherboard you will also be able to access the front camera, the power button, and the volume button.
必要な工具と部品
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
3 の人々がこのガイドを完成させました。
