はじめに
Samsung Galaxy S6からリアガラスパネルを取り出すと付けられた接着剤を剥がすことになります。このガイドを使ってSamsung Galaxy S6のリアガラス上に貼る接着テープを交換してください。大体の接着ストリップは画像にあるようにパッケージに入っていますが、フィルムのサイズや色は異なります。
まず作業を始める前に、ガラスパネルに残った接着剤をリントフリーの布を使ってイソプロピルアルコール(90%以上)で綺麗に拭き取ってください。
必要な工具と部品
141 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
9 件のコメント
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
I snagged a replacement front and back glass adhesive and a new daughter board for the S6 from http://www.mobiledefenders.com/. They seem okay so far. Only about a buck for the adhesives, plus shipping.
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
While cleaning off the old adhesive the rear housing broke into 3 pieces??!! I was using a kitchen table place mat….I would have appreciated the author giving me a heads up on how fragile the rear cover is.
It’s glass. That should be warning enough.
