メインコンテンツにスキップ
Samsung Galaxy S5 Sport Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 2、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 2、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 2、 3の画像 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 手順 3、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 手順 3、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: 手順 3、 3の画像 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 4、 2の画像 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 手順 5、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 手順 5、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: 手順 5、 3の画像 3
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 6、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 6、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 6、 3の画像 3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 7、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 7、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
  8. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 手順 8、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 手順 8、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: 手順 8、 3の画像 3
  9. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 9、 2の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 9、 2の画像 2
    • Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
  10. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 10、 2の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    • Remove the black connector above the wires by pulling straight up with tweezers.
  11. Samsung Galaxy S5 Sport Motherboard Replacement: 手順 11、 3の画像 1 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 11、 3の画像 2 Samsung Galaxy S5 Sport Motherboard Replacement: 手順 11、 3の画像 3
    • Pull the motherboard out. It should lift easily out of the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Caroline Janiszewski
メンバー登録日: 02/24/16
531 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016人のメンバー
USFT-LEAHY-S16S1G6
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 21
今までの合計 1,641
