はじめに
This guide will show someone how to safely remove the motherboard from the device. It is rather easy to do after the front screen and the plate underneath it are removed.
Note: In order to replace the motherboard, you will have to remove the screen. Because this is a waterproof phone the screen will most likely break during its removal. Be prepared to have to replace the screen as well.
必要な工具と部品
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
ある他の人がこのガイドを完成しました。
