メインコンテンツにスキップ
Samsung Galaxy S5 Sport Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: 手順 3、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: 手順 3、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: 手順 3、 3の画像 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 4、 2の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 4、 2の画像 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 3
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 6、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 6、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 6、 3の画像 3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 7、 3の画像 1 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 7、 3の画像 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Caroline Janiszewski
メンバー登録日: 02/24/16
528 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016人のメンバー
USFT-LEAHY-S16S1G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 626
