はじめに
Use this guide to replace the motherboard.
必要な工具と部品
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
Use a plastic opening tool to pry up the plastic midframe connector panel.
Remove the connector panel with a pair of tweezers.
Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
Carefully wedge the tip of a spudger underneath the antenna cable connector.
Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
Use the flat end of a spudger to disconnect the front-facing camera connector off its socket on the motherboard.
Remove the front-facing camera from the motherboard.
87 の人々がこのガイドを完成させました。
25 件のコメント
Do you know if I can put a g900p motherboard in the G900I in order to get FM radio. Cheers.
James Dean - 返信
In Step 28 you will figure out that there is a second antenna cable that is brown and needs to be detached as well. It is alligned in one row with the blue antenna cable.
I want to use the motherboard from a T-Mobile galaxy s5 on an AT&T galaxy s5 I just wanted to know if it fits inside the att version because my SIM card reader is broken so I wanted to know if I could use one from T-Mobile and that it would fix and work
It would fit and work
I dropped my Galaxy S5, gps for maps, compass etc... works fine, but for Endomondo and Strava that requires a location is not working, before the problem it showed GPS signal Ready, Now it just keeps ideling looking for location (GPS), dissasemble to check for any loose connector or loose screw and found nothing, What can be wrong and how to fix it?
Regards
Ralph Wall - 返信
