はじめに
For the official iFixit guide to repair your Galaxy S5 motherboard, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
必要な工具と部品
Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
Gently slide out the SD card using your fingernail or a plastic opening tool.
Use a light amount of force when removing the screen.
Starting at the top of the device, work the plastic opening tool under the screen. The top of the device has the Samsung logo and headphone port.
Start separating the screen from the glue. Work your way around the screen until the glue is no longer holding the screen in place.
During this operation I destroyed display. Display was glued from back to the phon. So if you even softly touch it, it will crack.
Start lifting the screen from the top. You will see a black ribbon cable attaching the display to the motherboard. Use the plastic opening tool to lightly detach the connector.
Continue to lift the display. You will notice a black cable connecting the home button to the motherboard.
Use the plastic opening tool to pry the home button off. Moderate force is required.
When gluing the home button back to the display, is there a particular glue I should use?
Unscrew the ten 4 mm screws from the midframe with a Phillips#00 head screw driver. You may want to use tweezers or a magnetic screwdriver to remove them.
Flip the phone back over. First, unlatch the charging port flap at the bottom of the device with your finger.
Press firmly on corners of the midframe while holding on to the plastic bezel (the outer plastic ring).
Hold the device in one hand. Then apply pressure with your fingers to the back of the frame at the top of where the battery was. Then remove the midframe by pulling it outwards and towards the top of the phone.
Remove the single silver 4 mm screw from below the rear camera with a Phillips#00 screw driver.
10 の人々がこのガイドを完成させました。
6 件のコメント
hi
guys please i need some help
Hey guys need some help. 3 yr old Galaxy S5. When trying to turn on, It repetitively keeps trying to boot does not even make it past the main screen. I believe my motherboard is shot. The battery is fine. Seeing how I can’t turn phone on to transfer my contacts. Can anyone get my contacts out of it. I am not willing to pay the price of another phone to do so though. That is plain crazy talk.
Nice work for my phone setting
BhupSinghBhadu Baf - 返信
Thanks very much A better replace ment
