メインコンテンツにスキップ
はじめに
Prerequisite only
  1. Insert a fingernail or a plastic opening tool into the slot located above the power button. Gently pull the panel off the back of the phone. The plastic snaps will make a popping sound as they separate.
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
  2. Insert fingernail or plastic opening tool into the slot at the bottom of the battery. Gently pry the battery away from the phone. When replacing the battery, ensure the contacts are aligned and press lightly.  The battery will appear to fit in multiple directions, so do not force it in.
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
    • Flip the phone and lay it on a flat surface so that the back is facing towards you.
    • Use a spudger or plastic opening tool to pry up the home button cable connector and disconnect it.
    • For reassembly, insert the home button cable connector through the open slot in the display assembly.
    • Use an iOpener to loosen the adhesive beneath the display.
  3. Flip the phone over so it is lying on its back. Insert a plastic opening tool or a plastic opening pick in the space between the screen and the frame and slide along the right side of the phone to loosen the adhesive. Gently lift the display assembly away from the frame until there is a small gap and leave the first opening pick in the bottom right corner next to your home button.
    • Flip the phone over so it is lying on its back.
    • Insert a plastic opening tool or a plastic opening pick in the space between the screen and the frame and slide along the right side of the phone to loosen the adhesive.
    • Gently lift the display assembly away from the frame until there is a small gap and leave the first opening pick in the bottom right corner next to your home button.
    • Insert a second opening pick and slide it up to the top left corner of the phone by loosening the adhesive beneath the display.
    • Do not insert the opening pick more than 1/8 inch. There are some components that can be harmed.
  4. Reheat the display of your phone with the iOpener. Especially the top and left side of the front. Insert a third opening pick and slide it carefully to the top left corner of the phone. Be aware of the front camera and the loudspeaker! Insert a third opening pick and slide it carefully to the top left corner of the phone. Be aware of the front camera and the loudspeaker!
    • Reheat the display of your phone with the iOpener. Especially the top and left side of the front.
    • Insert a third opening pick and slide it carefully to the top left corner of the phone. Be aware of the front camera and the loudspeaker!
  5. Insert a fourth opening pick and slide it to the lower left corner next to your home button. Flip the opening pick in the top right corner to lift the display. If it is still sticky, move the four opening picks around the frame as you did before to find remains of adhesive. Do not remove the display assembly from the frame. It is still connected by a cable.
    • Insert a fourth opening pick and slide it to the lower left corner next to your home button.
    • Flip the opening pick in the top right corner to lift the display. If it is still sticky, move the four opening picks around the frame as you did before to find remains of adhesive.
    • Do not remove the display assembly from the frame. It is still connected by a cable.
  6. Keep the top portion of the display assembly next to the frame. Unplug the display flex connector with a spudger.
    • Keep the top portion of the display assembly next to the frame.
    • Unplug the display flex connector with a spudger.
    • Use a suction handle to lift the display off of your phone. The home button cable connector should go with the display through a small gap in the mid frame. If it doesn't, use a tweezer to help a little.
    • Pull the display assembly away from the phone to remove it.
  7. Remove the 12 4 mm Phillips screws #00 from the midframe.
    • Remove the 12 4 mm Phillips screws #00 from the midframe.
  8. Flip the phone over and lay it on a flat surface so that the back is facing towards you.
    • Flip the phone over and lay it on a flat surface so that the back is facing towards you.
    • Unscrew the 4 mm Phillips #00 screw next to the battery slot.
  9. Circle the midframe with a  blow dryer or use the iOpener to loosen the adhesive on the midframe.
    • Circle the midframe with a blow dryer or use the iOpener to loosen the adhesive on the midframe.
    • Circling the midframe for 10 to 30 seconds with a blowdryer should loosen the adhesive enough.
  10. Spread pressure out evenly to avoid damage or bending of the midframe. Apply pressure to the battery slot on back of the phone to separate the midframes. Apply pressure to the battery slot on back of the phone to separate the midframes.
    • Spread pressure out evenly to avoid damage or bending of the midframe.
    • Apply pressure to the battery slot on back of the phone to separate the midframes.
  11. Unscrew the 3 mm Phillips #00 screw holding the daughterboard to the motherboard assembly. Use a plastic opening tool or spudger to pry the daughterboard from its socket. Use tweezers to pull the cables connecting the daughterboard out from the motherboard.
    • Unscrew the 3 mm Phillips #00 screw holding the daughterboard to the motherboard assembly.
    • Use a plastic opening tool or spudger to pry the daughterboard from its socket.
    • Use tweezers to pull the cables connecting the daughterboard out from the motherboard.
  12. Remove the 3 mm Phillips #00 screw holding the motherboard to the frame. Pull the motherboard from the frame and lay it on a flat surface. Pull the motherboard from the frame and lay it on a flat surface.
    • Remove the 3 mm Phillips #00 screw holding the motherboard to the frame.
    • Pull the motherboard from the frame and lay it on a flat surface.
終わりに
ある他の人がこのガイドを完成しました。
Jon Kuzmich
メンバー登録日: 2014年09月29日
1,930 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 12-4, Forte Fall 2014 Cal Poly, Team 12-4, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G4
5 メンバー
38のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
