メインコンテンツにスキップ
Samsung Galaxy S5 Mini Battery Replacement
必要な工具と部品
  1. Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 手順 1、 3の画像 1 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 手順 1、 3の画像 2 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 手順 1、 3の画像 3
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
    Hi, Yesterday I added a comment (although I can’t it on the site right now) I stated that the back on my S5 Mini was stuck on, not held by clips as you say in your S5 instructions. This was wrong. ''''
    ''''I wrongly thought my phone was an S5 Mini when in fact it’s an S6. I had forgotten that I had upgraded to the S6 some time ago and had not disposed of the S5 box etc. I will now rest my three remaining brain cells before attempting the repair of the S6.
    Richard Kelsall - 返信
  2. Samsung Galaxy S5 Mini Battery Replacement, Battery: 手順 2、 3の画像 1 Samsung Galaxy S5 Mini Battery Replacement, Battery: 手順 2、 3の画像 2 Samsung Galaxy S5 Mini Battery Replacement, Battery: 手順 2、 3の画像 3
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Ethan Juhnke
メンバー登録日: 09/29/14
162 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-4, Forte Fall 2014 Cal Poly, Team 12-4, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G4
5 メンバー
38のガイドは作成済み
2 件のコメント
that was so so hard!
dennysb de - 返信
But battery not charging properly
kapil jadhav - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 36
今までの合計 10,239
