メインコンテンツにスキップ
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
必要な工具と部品
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: 手順 1、 1の画像 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 2、 1の画像 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 3、 1の画像 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 手順 4、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 手順 4、 2の画像 2
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: 手順 5、 1の画像 1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: 手順 6、 1の画像 1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 7、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 7、 2の画像 2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 8、 1の画像 1
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 9、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 9、 2の画像 2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 10、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 10、 2の画像 2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 11、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 11、 2の画像 2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 12、 3の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 12、 3の画像 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 12、 3の画像 3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 13、 2の画像 1 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 手順 13、 2の画像 2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Richard
メンバー登録日: 02/07/17
30,000 ポイント
11のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,767のガイドは作成済み
コメント 1 件
Thank You so much!
Peter Handless - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 5,178
