メインコンテンツにスキップ
Samsung Galaxy S4 Active Volume Button Replacement
必要な工具と部品
  1. Samsung Galaxy S4 Active Volume Button Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S4 Active Volume Button Replacement, Rear Case: 手順 1、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Volume Button Replacement, MicroSD Card: 手順 2、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Volume Button Replacement, Battery: 手順 3、 1の画像 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Volume Button Replacement, SIM Card: 手順 4、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Volume Button Replacement, Midframe: 手順 5、 1の画像 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Volume Button Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Volume Button Replacement, Volume Button: 手順 7、 1の画像 1
    • Pull the volume button out with a pair of blunt nose tweezers.
  8. Samsung Galaxy S4 Active Volume Button Replacement: 手順 8、 3の画像 1 Samsung Galaxy S4 Active Volume Button Replacement: 手順 8、 3の画像 2 Samsung Galaxy S4 Active Volume Button Replacement: 手順 8、 3の画像 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  9. Samsung Galaxy S4 Active Volume Button Replacement: 手順 9、 1の画像 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  10. Samsung Galaxy S4 Active Volume Button Replacement: 手順 10、 1の画像 1
    • Remove the motherboard.
  11. Samsung Galaxy S4 Active Volume Button Replacement: 手順 11、 1の画像 1
    • Flip
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
89,956 ポイント
89のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 815
