メインコンテンツにスキップ
Samsung Galaxy S4 Active Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: 手順 1、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Motherboard Replacement, MicroSD Card: 手順 2、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Motherboard Replacement, Battery: 手順 3、 1の画像 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Motherboard Replacement, SIM Card: 手順 4、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Motherboard Replacement, Midframe: 手順 5、 1の画像 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Motherboard Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the motherboard.
終わりに
22 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
90,216 ポイント
89のガイドは作成済み
4 件のコメント
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Justin Lujan - 返信
Nota1000 fera + parabéns
ricflavianoop - 返信
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
Markus Elgrande - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 9,330
