メインコンテンツにスキップ
Samsung Galaxy S4 Active Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: 手順 1、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Front Facing Camera Replacement, Battery: 手順 2、 1の画像 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  3. Samsung Galaxy S4 Active Front Facing Camera Replacement, MicroSD Card: 手順 3、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  4. Samsung Galaxy S4 Active Front Facing Camera Replacement, SIM Card: 手順 4、 1の画像 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Front Facing Camera Replacement, Midframe: 手順 5、 1の画像 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Front Facing Camera Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 1 Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the single 0.3mm screw securing the black cover over the camera sensor.
  8. Samsung Galaxy S4 Active Front Facing Camera Replacement: 手順 8、 2の画像 1 Samsung Galaxy S4 Active Front Facing Camera Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using a pair of precision tweezers, remove the black camera backing.
  9. Samsung Galaxy S4 Active Front Facing Camera Replacement: 手順 9、 2の画像 1 Samsung Galaxy S4 Active Front Facing Camera Replacement: 手順 9、 2の画像 2
    • Using a spudger, disconnect the blue press-fit connector by pulling up gently.
    • Lift the front-facing camera out of the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Justin Ogihara
メンバー登録日: 09/18/17
27,656 ポイント
52のガイドは作成済み
チーム
EDU Team EDU Team人のメンバー
Staff
7 メンバー
677のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 533
