必要な工具と部品
Using a heat gun, heat the device to 174°F (78°C). Make sure to heat the back side too
Apply isopropyl alcohol to the edges of the plastic card
Slowly slide the plastic card around all around the device. Make sure to slide through all of the adhesives while applying small amounts of pressure to pry the glass off
Unscrew the 6 screws holding down the wireless charging bracket
Carefully remove the bracket without tearing the wireless charging pad
Next, disconnect the wireless charger
Disconnect the battery and all of the highlighted flex cables
Remove the 7 screws holding down the plate containing the loudspeaker
Remove the plate
Pry up the edge (mine was the left side) with the iSesimo. Fill the battery socket with alcohol, and slowly pry the battery and let it come out on its own
Remove the 3 screws and then the 2-5G antennas
Apply a small amount of heat, and remove the buttons
4 の人々がこのガイドを完成させました。
3 件のコメント
This guide says it's for the screen but it only explains how to remove the back glass?
Hi, This guide talks about heating, breaking glue seal to get back off then alcohol to release battery. No mention of correct replacement for glue failure. Step3 picture identifies screws correctly other steps call for screw removal without good id.
هل يوجد بقية
