はじめに
If you are having a lot of issues with signal reception, you may want to replace your antenna. Or if you would rather not, you may just want to buy a new phone.
必要な工具と部品
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
もう少しです!
終わりに
