はじめに
Drop your phone one too many times? Cracked screen? Replace it quickly and at a low cost by following this guide.
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
Pull the antenna cable out.
Locate the three snap on ribbon cable connectors on the motherboard.
Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
Use a heat gun or hairdryer to loosen the adhesive that secures the touch panel to the screen assembly.
6 の人々がこのガイドを完成させました。
