メインコンテンツにスキップ
Samsung Galaxy S III LCD Display/Front Glass Replacement
必要な工具と部品
  1. Samsung Galaxy S III LCD Display/Front Glass Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement, Rear Case: 手順 1、 2の画像 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 2、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 2、 2の画像 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 3、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 3、 2の画像 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 4、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 4、 2の画像 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 5、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 5、 2の画像 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III LCD Display/Front Glass Replacement, SIM Card: 手順 6、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement, SIM Card: 手順 6、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement, SIM Card: 手順 6、 3の画像 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  7. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 7、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 7、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 7、 3の画像 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  8. Samsung Galaxy S III LCD Display/Front Glass Replacement, microSD Card: 手順 8、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement, microSD Card: 手順 8、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement, microSD Card: 手順 8、 3の画像 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  9. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 9、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 9、 2の画像 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  10. Samsung Galaxy S III LCD Display/Front Glass Replacement, Front Glass: 手順 10、 1の画像 1
    • If your phone already has a protective screen applied to it, you are ready to begin.
    • If it doesn't, cut a piece of packaging tape the size of the screen and apply it to the screen. This will help you remove the broken glass later.
  11. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 11、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 11、 2の画像 2
    • With a plastic opening tool, pry open the back case. It will come out very easily.
  12. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 12、 1の画像 1
    • Take out the battery. There are no cables attached.
  13. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 13、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 13、 2の画像 2
    • If your provider/version of phone takes a SIM card, remove it by pushing it in a bit until you hear a small click, and then slide it out.
    • Sprint USA does not use SIM card.
  14. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 14、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 14、 2の画像 2
    この手順で使用する道具:
    Heat Gun
    $24.99
    購入する
  15. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 15、 1の画像 1
    • You need to have lots of patience in this procedure. Take your time.
    • Using an infrared thermometer heat the surface to 170-180° F (roughly 70-80° C). This will loosen the glue but not damage the electronics.
    • Hold the gun at about 3 inches from your phone (in this picture it looks like its right on top). With the heat gun set to low, heat up the borders for about 3 to 5 minutes depending on the strength of your heat gun.
    • You must be careful when using the heat gun on this device. If the device is heated up too much then it may melt the digitizer and cause discoloration. If you start to see any discoloration then shut off the gun immediately.
    • If you are working with a hair dryer, it might take up to 1 hour.
    • This melts the glue that holds the glass to the frame and to the display. The glass is glued to them.
  16. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 16、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Picks (Set of 6)
    購入する
    • Using a guitar pick or a plastic opening tool, very carefully start to work separating the edges of the glass.
    • Make sure to go from top to bottom.
    • You will need to use the heat gun a number of times as you go down separating the glass. For glasses with lots of damage you will need to go extra carefully as to not damage the LCD with the shattered glass pieces.
  17. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 17、 1の画像 1
    • When you start separating the screen, you need to start from the top borders and work your way to the center, ungluing the whole screen from top to bottom. Leave some opening tools in to prevent the glass from bonding again to the LCD.
    • Be extra careful when you get to the bottom because the menu buttons are glued to the glass.
    • Do not pull the glass just yet, you might damage the cables. Pull the screen from the top to the bottom to the point where you can see the menu and return button cables.
  18. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 18、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 18、 2の画像 2
    • Extra attention is necessary with this step, don't damage the buttons or cable! With a spudger, detach the buttons from the inner side of the glass. This might require a little extra heat. Also, the best strategy is to start in the middle, under the black ribbon that connects the two buttons, and then move sideways to separate each one.
    • *Edit* Thanks to the awesome guy or gal who uploaded the missing pics ^__^
  19. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 19、 1の画像 1
    • Take out the broken glass. I was able to take it all in one piece.
    • If your glass is very shattered you will need to pick up the small pieces with tweezers, one by one or stick tape to the glass before you take it out. You can also use screen protectors.
  20. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 20、 1の画像 1
    • Take this small metal piece from your old glass, you will need to put it in the new one.
  21. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 21、 1の画像 1
    • Clean up the glue that remains on the borders. A small microfiber with a bit of WD40 or windex can help you take all the glue off.
    • Be sure to not use too much WD40 or windex.
    • When cleaning out the glue, do NOT attempt to scrape glue out of the cracks between the LCD and the frame. A very small amount of force toward the center or from underneath will crack the LED.
    • Cut up two small 1mm pieces of the sticker tape and glue the buttons to the phone to keep them in place.
    • It's very important to make sure the buttons line up exactly with the picture.
  22. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 22、 1の画像 1
    • Put pieces of the sticker tape along the inner frame of the phone.
    • Clean up the digitizer with lint free wipes or a clean microfiber towel. I used some lens cleaner to leave it spotless and smudge free.
  23. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 23、 1の画像 1
    • Take out the plastic from the new glass, make sure you dont touch the inner side of the screen.
    • There are thin protective plastic layers on both sides of the glass. Peel them out before placing the glass on your phone.
  24. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 24、 1の画像 1
    • Check the glass against the light to make sure it is streak free before applying. If packaging left noticeable marks clean with glass cleaner and let dry before applying
    • Peel off the paper from the sticker tape and put on the new glass. Press on the edges to secure adhesion.
  25. Samsung Galaxy S III LCD Display/Front Glass Replacement, Plastic Midframe: 手順 25、 1の画像 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  26. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 26、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 26、 2の画像 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  27. Samsung Galaxy S III LCD Display/Front Glass Replacement, LCD: 手順 27、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement, LCD: 手順 27、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement, LCD: 手順 27、 3の画像 3
    • Use the spudger to gently pry the display data cable from the motherboard.
  28. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 28、 1の画像 1
    • Using the marvellous iOpener start to loosen the adhesive holding the display to the case.
    • This will take time and will require many reheats
    • Ensure you wait 2 mins before reheating the iOpener
    • Start at the top of the screen and work your way down
  29. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 29、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 29、 2の画像 2
    • Use one of the picks to lift the display in one of the corners
    • Work the pick along the top lifting the display from the case
    • Slide the plastic card into the top to provide some leverage
    • This will also stop the display from sticking back down to the case while you work down the display
  30. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 30、 1の画像 1
    • As you work you will want to reheat the iOpener and put it back on the display to melt the adhesive further down the screen
  31. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 31、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 31、 2の画像 2
    • Keep working down the phone
    • Inserting the picks into the sides to help lift the display as you slide the card down towards the bottom
    • If you remove the card and picks and can see the same view as in the second picture then you have the correct separation of parts
  32. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 32、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 32、 2の画像 2
    • The two touch buttons need to be separated from the case
    • This should already be the case but incase you stuck them down earlier you should carefully pry them so they are loose
    • Be very careful not to damage the cable or buttons
  33. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 33、 1の画像 1
    • Once you reach the bottom you will want to be careful and remove the bottom left corner before lifting up the right
    • This is due to the connection cable being on the right which passes through the case
    • Use the pick to help pry the cabling away from the case without pulling too hard
  34. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 34、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 34、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 34、 3の画像 3
    • Once all the adhesive is separated lift the display to the right
    • Careful of the cable passing through the case
    • Separate the display from the case pulling the cable through the case
  35. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 35、 1の画像 1
    • Comparing a new display (in the centre) against the old one (on right) and the case (on left)
    • Note this replacement does NOT have the touch screen buttons
    • If yours does then skip the next step
  36. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 36、 2の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 36、 2の画像 2
    • Using a spudger very carefully lift the black lock on the connector
    • Gently pull the cable out of the connector
    • Using a pick very carefully separate the touchscreen cable from the display
    • The chip on the cable at that point is glued to the display but can be easily separated by sliding a pick under it
    • If it is not separating with ease place the iOpener on top this should loosen the adhesive.
  37. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 37、 1の画像 1
    • The old/broken display can now be disposed of
    • Keep the case
    • Keep the touchscreen buttons
  38. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 38、 3の画像 1 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 38、 3の画像 2 Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 38、 3の画像 3
    • Finally to tidy up the case
    • The adhesive strip (double sided tape) used to attach the old display probably did not come off with the display
    • Use the iOpener to loosen the adhesive
    • Use the picks to lift up the edges and then peel the strip off the case
    • This may again take several attempts with heating and picking, be patient, the slower you go the larger the strip you should be able to lift which should make it easier to take the whole thing off in one (or 3) goes
  39. Samsung Galaxy S III LCD Display/Front Glass Replacement: 手順 39、 1の画像 1
    • Before putting the phone back together apply double sided tape to the case to hold the glass to the case
    • The LCD display should have some serious adhesive already on it. Make sure you remove the protective plastic to reveal it
    • if you're lucky your replacement screen may have custom 3M tape sections
    • To reassemble
    • Attach the touchscreen buttons to the new screen (Step 14)
    • Slide the cable through the case
    • Stick the display down to the case (apply pressure to make sure its stuck, but not too much you don't want to break the new screen)
    • Follow steps 1 - 5 in reverse to reassemble from the back
終わりに
64 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Ollie Freeman
メンバー登録日: 05/19/13
3,175 ポイント
1ガイドが承認済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 44
今までの合計 114,061
