はじめに
Use this guide to replace the front-facing camera.
必要な工具と部品
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Remove the single 2.0 mm Phillips screw securing the front-facing camera bracket to the front panel.
40 の人々がこのガイドを完成させました。
2 件のコメント
I have an s3 & no matter what I do , the front facing camera will not work, help !!!
robertmyatt62@yahoo.com
Yeah that's my problem too man. I did all the hard reset $@$* and nothing happened .
