はじめに
Use this guide to replace the battery.
If your battery is swollen, take appropriate precautions.
ツール
パーツ
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Lift up and remove the rear case from the phone.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
89 の人々がこのガイドを完成させました。
2 件のコメント
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - 返信
