はじめに
The speaker located on the back of the phone is a larger speaker that is housed in the protective inner plate. This speaker is used when no headphones are plugged in for media and the speakerphone function.
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm). Remove the screws with a Philips head precision screwdriver. Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. When removing the inner plate, place device on grounded surface or use anti static wrist band. After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone. Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  5. The speaker is located in the area located by the red rectangle. To remove the speaker hold the frame with one hand then push the speaker out with the other. It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
まとめ
2 の人々がこのガイドを完成させました。
Joshua King
メンバー登録日: 2014年03月26日
1,330 ポイント
9のガイドは作成済み
チーム
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G5
4 メンバー
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,291
