はじめに
The most common use of the SIM card is for storing contacts and synchronizing with your mobile carrier. This small part is vital to the operation of the phone since it directly affects the ability to receive calls and messages as well as creating interruptions of service.
ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. The SIM card is the small white rectangle located in the red rectangle. To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal. To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
まとめ
Joshua King
メンバー登録日: 2014年03月26日
1,330 ポイント
9のガイドは作成済み
チーム
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G5
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 2,121
