メインコンテンツにスキップ
Samsung Galaxy S II T989 Inner Plate Replacement
必要な工具と部品
  1. Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: 手順 1、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: 手順 1、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement, Rear Cover: 手順 1、 3の画像 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: 手順 2、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: 手順 2、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement, SIM Card: 手順 2、 3の画像 3
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
  3. Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: 手順 3、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: 手順 3、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement, Media Card: 手順 3、 3の画像 3
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
  4. Samsung Galaxy S II T989 Inner Plate Replacement, Battery: 手順 4、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement, Battery: 手順 4、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement, Battery: 手順 4、 3の画像 3
    • Turn off the phone before removing battery.
    • The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
    • After the battery starts to lift upwards, use your hand to hold and remove it.
  5. Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: 手順 5、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: 手順 5、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement, Inner Plate: 手順 5、 3の画像 3
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  6. Samsung Galaxy S II T989 Inner Plate Replacement: 手順 6、 3の画像 1 Samsung Galaxy S II T989 Inner Plate Replacement: 手順 6、 3の画像 2 Samsung Galaxy S II T989 Inner Plate Replacement: 手順 6、 3の画像 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
終わりに
作成者
6人の作成者と共同で作成されました。
Joshua King
メンバー登録日: 03/26/14
1,378 ポイント
9のガイドは作成済み
チーム
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G5
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,374
