はじめに
The front facing camera is smaller than the rear camera. This small camera is held in place by plastic bar attached to the case by a screw.
必要な工具と部品
To remove the rear cover, locate the tab indicated by the red outline.
Using your fingernail, gently pry the rear cover.
The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
After the battery starts to lift upwards, use your hand to hold and remove it.
The SIM card is the small white rectangle located in the red rectangle.
To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
この手順で使用する道具:Magnetic Project Mat$19.95
The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
Remove the screws with a Philips head precision screwdriver.
Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
To remove the motherboard, first undo the three tabs, indicated by the red outlines, using either a small flat-head screwdriver or your thumbnail.
In addition to the three at the top of the motherboard, there is a fourth tab at the bottom of the phone that will need to be opened as well.
To remove the front camera we need to first remove the screw indicated by the red circle and the cover plate. The screw size is 1/16 of an inch (1.6 mm)
After the screw has been removed, the cover plate can be removed.
3 の人々がこのガイドを完成させました。
