メインコンテンツにスキップ
Samsung Galaxy Rush Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Rush Motherboard Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy Rush Motherboard Replacement, Rear Case: 手順 1、 2の画像 2
    • Looking at the back of your phone, use your finger to remove back cover.
  2. Samsung Galaxy Rush Motherboard Replacement: 手順 2、 2の画像 1 Samsung Galaxy Rush Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the battery.
  3. Samsung Galaxy Rush Motherboard Replacement: 手順 3、 1の画像 1
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  4. Samsung Galaxy Rush Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Rush Motherboard Replacement: 手順 4、 2の画像 2
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  5. Samsung Galaxy Rush Motherboard Replacement, Connectors: 手順 5、 2の画像 1 Samsung Galaxy Rush Motherboard Replacement, Connectors: 手順 5、 2の画像 2
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
  6. Samsung Galaxy Rush Motherboard Replacement: 手順 6、 2の画像 1 Samsung Galaxy Rush Motherboard Replacement: 手順 6、 2の画像 2
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
  7. Samsung Galaxy Rush Motherboard Replacement: 手順 7、 1の画像 1
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  8. Samsung Galaxy Rush Motherboard Replacement: 手順 8、 1の画像 1
    • Lift the motherboard upwards separating it from your screen.
  9. Samsung Galaxy Rush Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • At this point your motherboard is separated from the screen.
  10. Samsung Galaxy Rush Motherboard Replacement: 手順 10、 1の画像 1
    • Just swap in the new motherboard and reassemble.
終わりに
作成者
4人の作成者と共同で作成されました。
Kenny Afiadata
メンバー登録日: 10/20/14
34 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G4
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 9
今までの合計 371
