メインコンテンツにスキップ
Samsung Galaxy R Rear Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 2 Samsung Galaxy R Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Rear Facing Camera Replacement, Battery: 手順 2、 3の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Battery: 手順 2、 3の画像 2 Samsung Galaxy R Rear Facing Camera Replacement, Battery: 手順 2、 3の画像 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Rear Facing Camera Replacement, Remove screws: 手順 3、 2の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Remove screws: 手順 3、 2の画像 2
    • With the Phillips head screwdriver, remove all seven 4.0mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: 手順 4、 3の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: 手順 4、 3の画像 2 Samsung Galaxy R Rear Facing Camera Replacement, Bottom Panel: 手順 4、 3の画像 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: 手順 5、 3の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: 手順 5、 3の画像 2 Samsung Galaxy R Rear Facing Camera Replacement, Top Panel: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to grasp the vibrator firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: 手順 6、 3の画像 1 Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: 手順 6、 3の画像 2 Samsung Galaxy R Rear Facing Camera Replacement, Rear Camera: 手順 6、 3の画像 3
    • The rear facing camera is located near the top center on the underside of the motherboard.
    • To remove the camera, flip the orange clip circled in red and pull the camera from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Keon Horahan
メンバー登録日: 10/13/14
841 ポイント
6のガイドは作成済み
チーム
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G3
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 331
