Insert an opening tool or fingernail into the tab on the power button side of the phone.
Lift on the tab to pry the back cover off of the phone.
Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
To remove the SD card and Sim card, look above the battery bay and slide the card out.
Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
You can also push the screen out in the empty slot where the battery was to separate.
It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
Lift from the top of the loudspeaker unit to release from the phone.
You do not need to remove the motherboard to do this.
The mother board should now be free to remove.
Carefully lift each edge and lift to remove.
Flip the mother board over and use a plastic spudger to disconnect the rear facing camera ribbon connector to free the camera.
Make sure not to overly bend the ribbon connector.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
