この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Insert an opening tool or fingernail into the tab on the power button side of the phone.
Lift on the tab to pry the back cover off of the phone.
Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
Remove the SD card and Sim card located above the battery bay. (first image)
Lift up the plastic plate that covers the LCD ribbon cable. (second image)
Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back. (their spots are indicated in the image)
Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
Insert an opening tool or credit card between the screen and plastic bezel, then apply pressure to separate.
3 の人々がこのガイドを完成させました。
