メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. To remove the SD card and Sim card,  look above the battery bay and slide the card out. Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
    • To remove the SD card and Sim card, look above the battery bay and slide the card out.
    • Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
  4. Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Keep the screws on a magnetic mat or in a secure location.
  5. Use a heat gun or a heating device to lightly heat the edges of the screen on the phone Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to separate.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  6. Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit. Lift from the top of the loudspeaker unit to release from the phone.
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone.
    • You do not need to remove the motherboard to do this.
  7. Use a plastic spudger to disconnect the ribbon cable from the motherboard.
    • Use a plastic spudger to disconnect the ribbon cable from the motherboard.
    • The camera will be free to remove.
終わりに
Alex Boyle
メンバー登録日: 2018年07月31日
329 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team S1-G1, Liner Summer 2018 UW Tacoma, Team S1-G1, Liner Summer 2018人のメンバー
UWT-LINER-SU18S1G1
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 23
今までの合計 208
