メインコンテンツにスキップ
はじめに
By following this guide you should be able to replace the headphone jack in 10-20 minutes. By replacing the headphone jack, you will fix any headphone related audio issues such as static, muffled sounds, or poor earphone audio quality.
パーツ
パーツは指定されていません。
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: 手順 1、 1の画像 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Headphone Jack Replacement: 手順 2、 1の画像 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Headphone Jack Replacement: 手順 3、 1の画像 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Headphone Jack Replacement: 手順 4、 1の画像 1
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Headphone Jack Replacement: 手順 5、 1の画像 1
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
  6. Samsung Galaxy Prevail Headphone Jack Replacement: 手順 6、 2の画像 1 Samsung Galaxy Prevail Headphone Jack Replacement: 手順 6、 2の画像 2
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
Ricardo Zuloaga
メンバー登録日: 2016年09月15日
525 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S17G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 235
