メインコンテンツにスキップ
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 手順 1、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 手順 1、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 手順 1、 3の画像 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 手順 2、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 手順 2、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 手順 2、 3の画像 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: 手順 3、 2の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: 手順 3、 2の画像 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 手順 4、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 手順 4、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 手順 4、 3の画像 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 手順 5、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 手順 5、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 手順 5、 3の画像 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 手順 6、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 手順 6、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 手順 6、 3の画像 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 手順 7、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 手順 7、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 手順 7、 3の画像 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 手順 8、 3の画像 1 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 手順 8、 3の画像 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 手順 8、 3の画像 3
    • Carefully lift and remove the camera from its position.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alexandra Hernandez
メンバー登録日: 10/08/14
741 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S14G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 10
今までの合計 1,404
