この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You may need to replace your battery if your current battery is damaged, or is not attaining power from an outlet. No background information is required.
必要な工具と部品
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
4 の人々がこのガイドを完成させました。
3 件のコメント
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
Mine doing the same
