メインコンテンツにスキップ
Samsung Galaxy Player 5.0 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Player 5.0 Battery Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Player 5.0 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the SD Memory Card before taking the device apart. Using the screwdriver, remove the 10mm Phillips screw that is near the SD Memory Card port.
  2. Samsung Galaxy Player 5.0 Battery Replacement: 手順 2、 1の画像 1
    • Remove the white caps, which are covering the screws that are located on either side of the charging port.
    • You may have to use a low heat blow dryer for 5 to 10 seconds, or other equivalent heat source to loosen the adhesive.
  3. Samsung Galaxy Player 5.0 Battery Replacement: 手順 3、 2の画像 1 Samsung Galaxy Player 5.0 Battery Replacement: 手順 3、 2の画像 2
    • Continue to unscrew the two 10mm Phillips Screws from the bottom of the device.
  4. Samsung Galaxy Player 5.0 Battery Replacement: 手順 4、 1の画像 1
    • Starting from the bottom and working around, use the prying tool to separate the front cover housing from the back cover housing.
    • You will hear a popping sound, indicating the separation.
  5. Samsung Galaxy Player 5.0 Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy Player 5.0 Battery Replacement: 手順 5、 2の画像 2
    • Take the back housing cover off of the device.
  6. Samsung Galaxy Player 5.0 Battery Replacement: 手順 6、 1の画像 1
    • Using the prying tool, remove the tab that attaches the battery to the motherboard.
  7. Samsung Galaxy Player 5.0 Battery Replacement: 手順 7、 3の画像 1 Samsung Galaxy Player 5.0 Battery Replacement: 手順 7、 3の画像 2 Samsung Galaxy Player 5.0 Battery Replacement: 手順 7、 3の画像 3
    • Then remove the battery, using the prying tool in an upward motion.
    • There is an adhesive behind the battery but it is not strong.
  8. Samsung Galaxy Player 5.0 Battery Replacement: 手順 8、 3の画像 1 Samsung Galaxy Player 5.0 Battery Replacement: 手順 8、 3の画像 2 Samsung Galaxy Player 5.0 Battery Replacement: 手順 8、 3の画像 3
    • Insert the new battery into its position, and reconnect its tab onto the motherboard.
  9. Samsung Galaxy Player 5.0 Battery Replacement: 手順 9、 1の画像 1
    • Now put the rear housing cover on the device, starting from its bottom side, and snap the edges all the way around to close the device.
  10. Samsung Galaxy Player 5.0 Battery Replacement: 手順 10、 3の画像 1 Samsung Galaxy Player 5.0 Battery Replacement: 手順 10、 3の画像 2 Samsung Galaxy Player 5.0 Battery Replacement: 手順 10、 3の画像 3
    • Lastly, reinsert the screws at the bottom of the device, as well as the screw beside the SD Memory Card port.
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
China Ayala
メンバー登録日: 03/05/15
584 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team 11-7, Blackburne Winter 2015 Sam Houston State, Team 11-7, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G7
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 3,525
