メインコンテンツにスキップ
Samsung Galaxy On5 Speaker Replacement
必要な工具と部品
  1. Samsung Galaxy On5 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Locate the side notch that allows you to open the back casing.
  2. Samsung Galaxy On5 Speaker Replacement: 手順 2、 3の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 2、 3の画像 2 Samsung Galaxy On5 Speaker Replacement: 手順 2、 3の画像 3
    • Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
  3. Samsung Galaxy On5 Speaker Replacement: 手順 3、 3の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 3、 3の画像 2 Samsung Galaxy On5 Speaker Replacement: 手順 3、 3の画像 3
    • Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
    • Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
  4. Samsung Galaxy On5 Speaker Replacement, Speaker: 手順 4、 2の画像 1 Samsung Galaxy On5 Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Before disassembling the phone, take out the SIM card and microSD card.
    • Use a plastic pry tool to slide both of the cards out.
    • Do not use a metal pry tool. Using this could cause damage to the cards and/or card holder.
  5. Samsung Galaxy On5 Speaker Replacement: 手順 5、 3の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 5、 3の画像 2 Samsung Galaxy On5 Speaker Replacement: 手順 5、 3の画像 3
    • Use the plastic Spudger tool to pry open the LCD ribbon cable cover.
    • This part might be a little hard to open. Take your time and be careful not to push too hard as doing so could result in damage to the ribbon.
  6. Samsung Galaxy On5 Speaker Replacement: 手順 6、 3の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 6、 3の画像 2 Samsung Galaxy On5 Speaker Replacement: 手順 6、 3の画像 3
    • Using a plastic pry tool, carefully pry the LCD ribbon cable from the logic board.
    • Do not use a metal pry tool. Metal pry tools can cause damage to the logic board and to the ribbon cable.
    • This LCD ribbon cable sends signal from the logic board to the LCD screen.
  7. Samsung Galaxy On5 Speaker Replacement: 手順 7、 2の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 7、 2の画像 2
    • Take a Phillips #00 head and remove all 9 screws. Once done place them aside where you won't lose them.
    • All 9 screws are the same size.
  8. Samsung Galaxy On5 Speaker Replacement: 手順 8、 2の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 8、 2の画像 2
    • Use an iFixit plastic pick to pry away the LCD from the back assembly.
    • This process will take some time due to the glue that's holding the LCD and back assembly together. Slowly move around the edge of the screen to loosen the glue up.
    • If you have a heat gun, you can use it to heat up the glue. Heating up the glue makes it easier to separate the LCD and back assembly.
  9. Samsung Galaxy On5 Speaker Replacement: 手順 9、 3の画像 1 Samsung Galaxy On5 Speaker Replacement: 手順 9、 3の画像 2 Samsung Galaxy On5 Speaker Replacement: 手順 9、 3の画像 3
    • Once both the LCD and back assembly come apart, look at the back assembly where the speaker is located.
    • Once located, take the plastic pry tool to remove the speaker from its housing and replace it with a new one.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
The Dark Night part 2
メンバー登録日: 09/19/18
983 ポイント
5のガイドは作成済み
チーム
Gateway, Team S1-G5, Luster Fall 2018 Gateway, Team S1-G5, Luster Fall 2018人のメンバー
GCC-LUSTER-F18S1G5
1 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 983
