メインコンテンツにスキップ
Samsung Galaxy Note5 Volume Button Replacement
必要な工具と部品
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: 手順 1、 1の画像 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: 手順 2、 1の画像 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: 手順 3、 1の画像 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: 手順 4、 1の画像 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: 手順 5、 1の画像 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: 手順 6、 1の画像 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: 手順 7、 1の画像 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: 手順 8、 1の画像 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: 手順 9、 2の画像 1 Samsung Galaxy Note5 Volume Button Replacement: 手順 9、 2の画像 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: 手順 10、 2の画像 1 Samsung Galaxy Note5 Volume Button Replacement: 手順 10、 2の画像 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: 手順 11、 2の画像 1 Samsung Galaxy Note5 Volume Button Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: 手順 12、 1の画像 1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 手順 13、 2の画像 1 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 手順 13、 2の画像 2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: 手順 14、 1の画像 1
    • Push out the volume button and remove it from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bernice Nunez
メンバー登録日: 04/19/18
340 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S25G17
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 1,277
