メインコンテンツにスキップ
はじめに
Use this guide to disconnect the battery and replace the wireless charging coil on your Samsung Galaxy Note10.
  1. Completely power off your phone before you begin disassembly.
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Apply a suction cup to the heated edge of the back panel, as close to the edge as possible. If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel. Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive. Do not insert the opening pick more than halfway into the phone or you risk damaging internal components. Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive. Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing. Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
  5. Prepare an iOpener and apply it to the top edge of the phone for one minute.
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
  6. Insert a third opening pick into the gap on the top edge of the phone. Slide the opening pick to the top right corner, slicing the adhesive. Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
  7. Prepare an iOpener and apply it to the right edge of the phone for one minute.
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
  8. Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive. The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
  9. Lift up and remove the back panel. Lift up and remove the back panel. Lift up and remove the back panel.
    • Lift up and remove the back panel.
  10. Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  11. Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector. Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector. Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  12. While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it. While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  13. Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard. Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  14. Tilt the metal shielding up so you can grip it with your fingers. Peel the wireless charging coil up and away from the device. The wireless charging coil is secured to the phone with some light adhesive.
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
ある他の人がこのガイドを完成しました。
Carsten Frauenheim
メンバー登録日: 2020年03月10日
55,465 ポイント
293のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
140 メンバー
17,046のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 33
過去 30 日: 143
今までの合計 1,625
