メインコンテンツにスキップ
Samsung Galaxy Note USB Board Replacement
必要な工具と部品
  1. Samsung Galaxy Note USB Board Replacement, Stylus: 手順 1、 2の画像 1 Samsung Galaxy Note USB Board Replacement, Stylus: 手順 1、 2の画像 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note USB Board Replacement, Rear Case: 手順 2、 2の画像 1 Samsung Galaxy Note USB Board Replacement, Rear Case: 手順 2、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note USB Board Replacement: 手順 3、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 3、 2の画像 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note USB Board Replacement, Battery: 手順 4、 2の画像 1 Samsung Galaxy Note USB Board Replacement, Battery: 手順 4、 2の画像 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note USB Board Replacement, MicroSD Card: 手順 5、 3の画像 1 Samsung Galaxy Note USB Board Replacement, MicroSD Card: 手順 5、 3の画像 2 Samsung Galaxy Note USB Board Replacement, MicroSD Card: 手順 5、 3の画像 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note USB Board Replacement: 手順 6、 1の画像 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note USB Board Replacement, SIM Card: 手順 7、 2の画像 1 Samsung Galaxy Note USB Board Replacement, SIM Card: 手順 7、 2の画像 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note USB Board Replacement: 手順 8、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 8、 2の画像 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    My sim in not working in this phone what should I do
    soha Javed - 返信
  9. Samsung Galaxy Note USB Board Replacement, Midframe: 手順 9、 1の画像 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note USB Board Replacement: 手順 10、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 10、 2の画像 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note USB Board Replacement: 手順 11、 3の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 11、 3の画像 2 Samsung Galaxy Note USB Board Replacement: 手順 11、 3の画像 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note USB Board Replacement: 手順 12、 3の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 12、 3の画像 2 Samsung Galaxy Note USB Board Replacement: 手順 12、 3の画像 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note USB Board Replacement: 手順 13、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 13、 2の画像 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: 手順 14、 2の画像 1 Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: 手順 14、 2の画像 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note USB Board Replacement: 手順 15、 3の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 15、 3の画像 2 Samsung Galaxy Note USB Board Replacement: 手順 15、 3の画像 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note USB Board Replacement: 手順 16、 3の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 16、 3の画像 2 Samsung Galaxy Note USB Board Replacement: 手順 16、 3の画像 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note USB Board Replacement: 手順 17、 1の画像 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note USB Board Replacement: 手順 18、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 18、 2の画像 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note USB Board Replacement, USB Board: 手順 19、 1の画像 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  20. Samsung Galaxy Note USB Board Replacement: 手順 20、 1の画像 1
    • Lift the speaker enclosure from the display assembly.
  21. Samsung Galaxy Note USB Board Replacement: 手順 21、 2の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 21、 2の画像 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  22. Samsung Galaxy Note USB Board Replacement: 手順 22、 3の画像 1 Samsung Galaxy Note USB Board Replacement: 手順 22、 3の画像 2 Samsung Galaxy Note USB Board Replacement: 手順 22、 3の画像 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  23. Samsung Galaxy Note USB Board Replacement: 手順 23、 1の画像 1
    • Remove the USB board.
終わりに
51 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,647 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,732のガイドは作成済み
6 件のコメント
Using the Guides on online and the PDF guides made this repair easy and quick!
Joe - 返信
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Phil - 返信
Where in England could I buy the USB Board part?
Craig Pyle - 返信
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
john dingley - 返信
It's not the Galaxy Note GT-N7000!
costantino - 返信
Make sure to match the rev on the board! Now I can finally enjoy using the phone while plugged in again.
John Cobra - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 24,370
