メインコンテンツにスキップ
Samsung Galaxy Note Pro 12.2 USB Port Replacement
必要な工具と部品
  1. Samsung Galaxy Note Pro 12.2 USB Port Replacement, USB Port: 手順 1、 1の画像 1
    • Make sure the device is off before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 2、 1の画像 1
    • Using your finger, push up on the clip to disconnect from the device.
  3. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 3、 2の画像 1 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 3、 2の画像 2
    • Remove the two 3mm screws from the silver cover using the Phillips #00 screwdriver.
  4. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 4、 2の画像 1 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 4、 2の画像 2
    • Pop open the orange tab that is connected to the SD port using the plastic opening tool.
  5. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 5、 1の画像 1
    • Pop up the USB port with the plastic opening tool.
    • Make sure that you are pushing up from underneath the part and not placing the tool inside the USB port itself.
  6. Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 6、 2の画像 1 Samsung Galaxy Note Pro 12.2 USB Port Replacement: 手順 6、 2の画像 2
    • Using the plastic opening tool, carefully lift away the orange piece connected to the USB port.
    • This piece is glued down. Be careful as you peel it away from the device.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Tina Kong
メンバー登録日: 09/22/17
1,278 ポイント
5のガイドは作成済み
チーム
Central Washington University, Team S1-G4, Pengilly Fall 2017 Central Washington University, Team S1-G4, Pengilly Fall 2017人のメンバー
CWU-PENGILLY-F17S1G4
4 メンバー
10のガイドは作成済み
5 件のコメント
I have a problem with my note pro 12.2 wifi. The battery connector is broken and needs to be replaced on the motherboard. I want to do it right but can find No information online about removing the motherboard (I have found one that is very good for the 10.1) but there are cables on the 12.2 not on the 10.1 that I am not sure how to remove them.
Wayne De Groot - 返信
How about a battery connector replacement for the note pro 12.2 SM-P900 on motherboard.
Wayne De Groot - 返信
Great instruction set and photos. I was a little nervous cracking it open for the first time (not as bad as the first time I upgraded my PC, but close), but your pictures and instructions were aces! It would have gone easier if I’d realized earlier that clicking on the photos popped them out to a separate tab where I could zoom, but I figured that out soon enough. The general concensus on the opener tools are that they don’t last long. I’d have to agree with that. Mine took a beating trying to get the back off, but with your instructions, it’s fixed. Thanks!
Carol Lapp - 返信
I lost the two screws. What size are they and where can I purchase them? Thank you.
Russell Ichenberg - 返信
very good instructions, was very helpful.
But it's still makes trouble charging.
Can it be any other problem or reason? Something doing the opposite of loading, very frustrating.
Daniela Chrzanowski - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 40
今までの合計 4,290
