メインコンテンツにスキップ
Samsung Galaxy Note Pro 12.2 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Note Pro 12.2 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove the back cover with the blue plastic opening tool.
  2. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 2、 2の画像 1 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 2、 2の画像 2
    • Disconnect the five base connectors from the motherboard by using the blue opening tool to carefully remove the connectors.
  3. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the yellow tape on the ribbon cables before attempting to disconnect them from the motherboard.
    • Using the blue opening tool, pry on the black tab at the base connector of ribbon cables until it is flipped up and moves with ease. Then, pull the ribbon cable from the base connectors of the motherboard.
  4. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Potential damage to the motherboard could occur without supporting the black motherboard connector as the white cable connector is being removed.
    • Remove the power cable from the motherboard by prying slightly on both sides of the clip using tweezers.
  5. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 5、 3の画像 1 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 5、 3の画像 2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 5、 3の画像 3
    • Remove all three of the 3.0 mm screws using the Phillips #00 screwdriver.
    • It is easiest to pry on the points depicted in the pictures for the next step.
    • Use the blue plastic opening tool to pry the speakers up from the clips that hold them in place.
  6. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the motherboard using the blue opening tool while keeping any wires and connectors out of the way.
    • The motherboard should come out freely.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
La'Taja Long
メンバー登録日: 11/04/19
346 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S1-G3, Henning Fall 2019 IUPUI, Team S1-G3, Henning Fall 2019人のメンバー
IUPUI-HENNING-F19S1G3
3 メンバー
3のガイドは作成済み
コメント 1 件
Hi. Can i install sm-p905 motherboard into my sm-p900?
yem44 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 23
今までの合計 2,106
