はじめに
Use this guide to remove or replace your motherboard.
必要な工具と部品
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to carefully disconnect the display cable connector.
20 の人々がこのガイドを完成させました。
4 件のコメント
i need note 7000 motherboard
How much does it cost for buying a Samsung Galaxy Note4 motherboard ? And where will I get it in Bangalore
