メインコンテンツにスキップ
Samsung Galaxy Note Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Note Motherboard Replacement, Stylus: 手順 1、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, Stylus: 手順 1、 2の画像 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Motherboard Replacement, Rear Case: 手順 2、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, Rear Case: 手順 2、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 3、 2の画像 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Motherboard Replacement, Battery: 手順 4、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, Battery: 手順 4、 2の画像 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: 手順 5、 3の画像 1 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: 手順 5、 3の画像 2 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: 手順 5、 3の画像 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Motherboard Replacement, SIM Card: 手順 7、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, SIM Card: 手順 7、 2の画像 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 8、 2の画像 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Motherboard Replacement, Midframe: 手順 9、 1の画像 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Motherboard Replacement: 手順 10、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 10、 2の画像 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Motherboard Replacement: 手順 11、 3の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 11、 3の画像 2 Samsung Galaxy Note Motherboard Replacement: 手順 11、 3の画像 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Motherboard Replacement: 手順 12、 3の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 12、 3の画像 2 Samsung Galaxy Note Motherboard Replacement: 手順 12、 3の画像 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Motherboard Replacement: 手順 13、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 13、 2の画像 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: 手順 14、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: 手順 14、 2の画像 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Motherboard Replacement: 手順 15、 3の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 15、 3の画像 2 Samsung Galaxy Note Motherboard Replacement: 手順 15、 3の画像 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Motherboard Replacement: 手順 16、 3の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 16、 3の画像 2 Samsung Galaxy Note Motherboard Replacement: 手順 16、 3の画像 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Motherboard Replacement: 手順 17、 1の画像 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Motherboard Replacement: 手順 18、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 18、 2の画像 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: 手順 19、 2の画像 1 Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: 手順 19、 2の画像 2
    • Use a plastic opening tool to flip the release tab on the rear-facing camera cable ZIF connector.
    • Only pry on the tab, not the connector itself.
  20. Samsung Galaxy Note Motherboard Replacement: 手順 20、 2の画像 1 Samsung Galaxy Note Motherboard Replacement: 手順 20、 2の画像 2
    • Slide the tip of a spudger under the rear-facing camera cable to slide it out of the ZIF connector and free it from the light adhesive.
  21. Samsung Galaxy Note Motherboard Replacement: 手順 21、 1の画像 1
    • Remove the rear-facing camera.
終わりに
20 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
474,950 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,623のガイドは作成済み
4件のガイドコメント
from where I can get the motherboard for Samsung Galaxy note 3???
abdom911 - 返信
Can You Assist Me where can I purchase samsung GT- N7000 mother board. GALAXY NOTE 1
edcas2158 - 返信
i need note 7000 motherboard
rajeev kapoor - 返信
How much does it cost for buying a Samsung Galaxy Note4 motherboard ? And where will I get it in Bangalore
LIGHT BREEZE - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 62
今までの合計 37,090
