メインコンテンツにスキップ
Samsung Galaxy Note II Rear Facing Camera Assembly Replacement
必要な工具と部品
  1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 手順 1、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 手順 1、 2の画像 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 手順 2、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 手順 2、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 3、 3の画像 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 手順 4、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 手順 4、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 手順 4、 3の画像 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 手順 5、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 手順 5、 2の画像 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 6、 1の画像 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Midframe: 手順 7、 1の画像 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 8、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 8、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 8、 3の画像 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 9、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 9、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 9、 3の画像 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 10、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 10、 2の画像 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 11、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 11、 2の画像 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 12、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 12、 2の画像 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 13、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 13、 2の画像 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 14、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 14、 2の画像 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 手順 15、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 手順 15、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 手順 15、 3の画像 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  16. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 16、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 16、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 16、 3の画像 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 17、 3の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 17、 3の画像 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 17、 3の画像 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 18、 1の画像 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  19. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 19、 2の画像 1 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 19、 2の画像 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Facing Camera Assembly: 手順 20、 1の画像 1
    • Use a spudger to disconnect the rear-facing camera assembly cable connector.
  21. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 手順 21、 1の画像 1
    この手順で使用する道具:
    • Use tweezers, or your fingers, to remove the rear-facing camera assembly.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
474,941 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,618のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 12,311
