はじめに
Use this guide to replace the motherboard in your Samsung Galaxy Note II.
必要な工具と部品
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Use a spudger to disconnect the vibrator/power button assembly cable connector.
Disconnect the antenna cable connector.
Disconnect the display cable connector.
Use a spudger to disconnect the rear-facing camera assembly cable connector.
67 の人々がこのガイドを完成させました。
29 件のコメント
Hello Fellas,
My Note 2 has a busted wifi, bluetooth, and gps (it attempts to turn on the wifi but never actually does). I suspect it is a hardware issue since I have factory reset my phone (didn't fix the problem) and even updated the drivers on my phone. It seem to be a common problem with this phone. The only solution I have found online is to wack the back of my phone until the signal is fixed. This is a good temporary fix but the problem returns after a day or two (sometimes within hours). I was hoping I could maybe replace the wireless signal piece of hardware and finally fix my phone. Could someone point out the correct hardware piece, please. (btw: I do receive regular phone calls , text , and 4g data)
Thank you, Kevin
Great job Sam!
Just one question: What are the steps after Step 21?
It seems to end suddenly...
Secondly, where can I but a Note 2 motherboard?
Hey Fuz!
The guide ends at step 21, because the camera is the last thing to come off of the old motherboard, it will then be the first thing to go back on the replacement motherboard. All you have to do is follow the steps in reverse to reassemble the device. Unfortunately we don't sell the Note II motherboard right now, but a quick search on eBay brings up quite a few options!
